Category
Top » Security » Setting IEEE802.1X Authentication » Checking Error Information for IEEE802.1X Authentication
Category Top
Setting the System Manager Information
Attention (Specifying the System Manager Information)
Registering the Name of the Machine and Location
Specifying the Setting for Department ID Management
Registering Departments
Editing Departments
Activating the Department ID Management
Specifying Whether or Not to Receive a Print Job from an Unknown ID
Checking or Clearing the Count Information
Specifying Keys and Certificates/CA Certificates
Generating Keys and Certificates
Installing Keys and Certificates/CA Certificates
Verifying Keys and Certificates/CA Certificates
Registering Keys and Certificates/CA Certificates
Deleting Keys and Certificates/CA Certificates
Specifying SSL
Setting TLS Authentication Information
Setting TTLS/PEAP Authentication Information
Switching On/Off for IEEE802.1X Authentication
Attention (IEEE802.1X Authentication)
Entering PIN for Printing (Secure Printing)
Setting Secure Printing
Printing by Secure Printing
Configuring the Remote UI
Restricting Network Connections
Restricting Sending/Receiving to/from Specific IP Addresses
Restricting Sending/Receiving to/from Specific MAC Addresses
Monitoring/Controlling Devices by SNMP (SNMP Setting)
Setting SNMPv1
Setting SNMPv3
Obtaining Printer Management Information from Host
Setting the Permission for HTTP Communications
Setting Protocol Port Numbers
Setting the Dedicated Port
Restricting to Specify Destinations and Use the Sending Functions
Setting a PIN for the Address Book
Restricting Destinations that Can Be Specified
Restricting to Send Faxes from Your Computer
Restricting Sending from Job History
Confirming the Entered Fax Number
Restricting Sequential Broadcasts
Specifying Display Settings for the Job History
Restricting USB Port or USB Memory Usage
Restricting External Device Connections via USB
Restricting Storing of Data in Memory Media
Restricting Printing of Data in Memory Media
Collapse all|Expand all
07K4-0KH
You can check error information about IEEE802.1X authentication.
1
Press [] (Status Monitor/Cancel).
2
Select <Network Information> using [] or [] and press [OK].
3
Select <IEEE802.1X Error Information> using [] or [] and press [OK].
4
Check the information.
5
Press [] (Status Monitor/Cancel) to close the screen.
