If you use department ID management
You need to specify both the system manager ID and PIN to restrict the operation of <System Settings> in the operation panel or the operation of Remote UI. Otherwise, all users are recognized as the administration user, and every user can use <System Settings> on the operation panel and the Remote UI without restriction.
Specifying the system manager ID and system manager PIN
A number up to 7 digits can be specified.
If the number is less than 7 digits
Example: when you enter <321>, the number is specified as <0000321>. If you register numbers that start from <0>
Example: when you enter <02> <002>, the number is specified as <0000002>. You cannot register numbers that consist of only <0> consecutively such as <00>.
