Printing System Manager Data List
07K4-04A
Print the System Manager Data List.
The following items are printed.
Preferences
Timer Settings
Common Settings
Copy Settings
Fax Settings
Scan Settings
USB Direct Print Settings
Printer Settings
Adjustment/Maintenance
System Settings
Reports
Paper Settings
If an error code is displayed, see the following.
1
Press [
] (Report).
2
Select <Print Reports> using [
] or [
] and press [OK].
3
Select <System Manager Data List> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
4
Make sure that paper is loaded, and then press [OK].
Load paper of the type displayed on the screen.
5
Select <Yes> using [
] and press [OK].
Printing begins.
6
Press [
] (Report) to close the <Print Reports> screen.
