] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
Settings
Purpose
What to do
<Date Display Type>
Specify the date display format.
Select one of the following display formats using [
] or [ ] and press [OK].The formats include the following. MM/DD/YYYY
DD/MM YYYY
YYYY MM/DD
<12/24 Hour Clock>
Specify the time display format.
] or [ ] and press [OK].The formats include the following. 12 Hour (AM/PM)
24 Hour
<Current Time Settings>*
Specify the current time and date.
Use [
] or [ ] to enter time and date, or to switch between <AM> and <PM>. To move the cursor, press [ ] or [ ].![]() |
<Time Zone Settings>
Specify the time zone.
Select the time zone using [
] or [ ] and press [OK]. |
<Daylight Savings>
Specify whether to use daylight saving time.
To use daylight saving time,
Make sure to configure <Time Zone Settings> before configuring this setting (If you change <Time Zone Settings>, <Current Time Settings> is changed accordingly).
] (Menu) to close the menu screen.
