(1)
[Menu] key
Press to specify or register various settings.
[2-Sided] key
You can set 2-sided printing.
[Select Paper] indicator
Selected paper source turns on.
[Select Paper/Settings] key
Press to specify the paper size and type to load in the paper drawer or multi-purpose tray.
(2)
Mode switch keys
Press to switch the mode to copy, fax, scan or USB direct print.
(3)
[Reset] key
Resets the settings. (Resets the copy/scan/fax/USB direct print mode.)
(4)
[Status Monitor/Cancel] key
Press to check the status of jobs or cancel jobs. You can also check the status of the network and machine.
] Key |
Press to scroll up or to increase the value.
] Key |
Press to scroll down or to decrease the value.
] Key |
Press to return to the previous screen or move the cursor to the left.
Press to decrease the volume while the fax ring tone sounds.
] Key |
Press to proceed to the next screen or move the cursor to the right.
Press to increase the volume while the fax ring tone sounds.
[OK] key
Press to confirm an action or setting.
[Back] key
Press to return to the previous screen.
[View Settings] key
You can check the settings.
(5)
[Wi-Fi] indicator
Turns on when the machine is connected to Wireless LAN.
Numeric keys ([0]-[9])
Enter characters and numbers.
[*] key
Press to switch the character entry mode, and press to switch between pulse and tone dialing to send a fax.
[#] key
Press to enter symbols.
[Report] key
Press to manually print reports and lists. You can also specify whether to print a report automatically.
[Energy Saver] key
Press to manually set or cancel the Sleep mode. The Energy Saver indicator lights green while in the sleep mode.
[ID] key
Press to display the Department ID login window.
[Clear] key
Deletes characters and numbers.
(6)
[Scan > PC1] key/
[Scan > PC2] key |
When registering destinations etc., you can send the documents by scanning with one-touch.
[Secure Print] key
Used for secure print.
[Paper Save Copy] key
Press to cancel jobs.
[Stop] key
Reduce multiple documents to copy onto one sheet.
[Start] key
Press to start copying, scanning, sending a fax or USB direct print.
(7)
[Error] indicator
Blinks when an error occurs.
[Processing/Data] indicator
Blinks during transmission and turns on when the machine has waiting jobs.
(1)
[One-touch Speed Dial] keys
Press to select destinations registered in one-touch keys.
(2)
[Address Book] key
Searches recipients registered under one-touch keys or coded dial codes.
(3)
[Coded Dial] key
Specifies recipients.
(4)
[Recall] key
Redial the last number called. (Only enabled when the mode screens for fax, e-mail or file server operations are displayed.)
(5)
[Hook] key
Press when you want to dial without lifting up the handset of the external telephone or the handset.
(6)
[Pause] key
Press to insert a pause in the fax number.
