Laser MFP Drivers
Printer driver
You can print from an application to the machine once you have the printer driver installed on your computer.
Printer Drivers:
UFRII LT/UFRII LT (XPS)/PCL5e/PCL6/PS Printer Driver
Fax driver
If you install the fax driver on your computer, you can select "Print" from an application, select the Canon fax driver as a printer, and specify the output destination and options. The fax driver converts the data into an image that conforms to standard fax protocols so that the data can be printed or saved using the recipient's fax machine.
Scanner driver
You can use the machine as a scanner once you have the scanner driver installed on your computer.
Network Scan Utility
You need this utility software to use the machine as a network scanner. It is automatically installed along with the scanner driver.
MF Toolbox
The MF Toolbox provides a group of commands for you to open a scanned image in an application, send it as an e-mail attachment file, store it on the hard disk, etc.
Others
Presto! PageManager
You can handle scanned images in many ways using this software.
: Supported
: Not supported |
Windows XP
Windows Vista/7
Windows Server 2003/Server 2008
Printer driver
Fax driver
Scanner driver
MF Toolbox
Presto! PageManager
Supported only over network connections.
