Restrictions when using USB cable
The settings related to the print functions cannot be configured automatically.
IP Address
Even if the product's IP address is changed, the connection is maintained if the machine and the computer belong to the same subnet.
You may not be able to use the scan function if an IPv6 connection is used.
Device necessary for wired LAN connection
The machine does not come with a LAN cable, a router or a hub. Have cables or a hub ready as needed.
The machine supports 10BASE-T and 100BASE-TX connections. If you want to connect the machine to a 100BASE-TX Ethernet network, all the devices connected to the LAN (router, hub, LAN cable, and network board for computer) must support 100BASE-TX.
For details, refer to the instruction manual for your devices or contact their manufacturer. Device necessary for wireless LAN connection
The machine does not come with a wireless LAN router or any access points. You must have routers and access points ready as needed.
In order to use the machine in the wireless LAN environment, you need the 2.4 GHz LAN routers and/or access points which are compliant with IEEE802.11 (b/g or n).
For details, refer to the instruction manual for your devices or contact their manufacturer. |
To connect the machine to a switching hub
The connection may fail even if the network settings are configured correctly.
When this occurs, delay the startup of the machine's network connection. |
