The Printout Is Different from What Is Displayed on Screen (Windows XP and Server 2003)
Perform the following procedure.
<Cause> This problem may occur in some applications depending on the processing type of the print data.
Solution
If you are using the PCL/UFR II printer driver, performing the following procedure may be able to solve the problem.
Display the [Finishing] tab.
Click [Advanced Settings].
Change the [EMF Spooling] setting.
