Fill Patterns and Borders Are Not Printed in the Correct Color (Specified Color) Even When the Same Color Is Specified for Them
Perform the following procedure.
<Cause> A special process may be applied depending on the line width of the border so that thin lines are printed clearly.
Solution 1
Perform the following procedure in the printer driver.
Display the [Quality] tab.
Select the [Manual Color Settings] check box.
Click [Color Settings].
4.
Display the [Matching] tab.
5.
Set [Matching Method] for [Text] and [Graphics] to the same settings.
You can specify the same setting from the printer's control panel.
Solution 2
4.
5.
Select [Gamma Adjustment] in [Matching Mode].
6.
Change the gamma value for [Gamma].
The larger the value is, the darker in color the data is printed.
