Solution 1
Perform the following procedure in the printer driver.
You can specify the same setting from the printer's control panel.
Solution 2
Solution 3
If you are using the PS printer driver, set [RGB Source Profile] in the [Setup] Menu ([PS] Options) to [Canon HDTV gamma 1.5], [Canon HDTV gamma 1.8], or [Canon HDTV gamma 2.4].
Also, you can specify the same setting in the PS printer driver. For more details, see Help of the PS printer driver. |
