Colored Text Appears Blurred
Perform one of the following solutions according to the cause.
<Cause>A bold font is being used for the colored text.
Solution 1
Print again with thinner fonts.
Solution 2
Perform the following procedure in the printer driver.
Display the [Quality] tab.
Select the [Manual Color Settings] check box.
Click [Color Settings].
4.
Display the [Matching] tab.
5.
Set [Matching Method] to [Perceptual [Monitor Color Matched]]. You can specify the same setting from the printer's control panel.
