Solution
Perform the following procedure in the printer driver.
UFR II Printer Driver
Display the [Quality] tab
PCL Printer Driver
See Help of the PCL printer driver.
![]() You can specify the same setting from the printer's control panel.
Solution 1
Set [Output Profile] in the [PS] options to [PS Normal] or [PS Photo].
Solution 2
Set [RGB Pure Black Mode] in the [PS] options to [Off]. Also, you can specify the same setting in the PS printer driver. For more details, see Help of the PS printer driver.
