Solution 1
Remove the LAN cable once, and then connect it again.
Solution 2
Replace the LAN cable with another one, and then connect it.
Solution 1
Connect the LAN cable to the port on the hub with an " X " mark.
Solution 2
If the hub has an UP-LINK (cascade) switch, switch to " X."
Solution 1
Replace the cable with a straight LAN cable.
Solution 2
Connect the cross LAN cable to the UP-LINK (cascade) port on the hub. If the hub has an UP-LINK (cascade) switch, switch to the " = " side.
Solution 1
Make sure that the power of the hub is on.
Solution 2
Specify the communication settings for the print server according to the transmission speed of the connected hub.
Solution
Contact your local authorized Canon dealer to request service.
