When Selecting Keys and Certificates
A key and certificate need to be generated for encrypted SSL traffic. For more information, see "Setting Keys and Certificates."
About [Default Key Settings]
[Default Key Settings] is only displayed when the key is not specified as use key.
To prevent keys in use from being changed, [Default Key Settings] is not displayed in the following cases.
[Use SSL] under [Remote UI Settings] is set to ON.
[SSL] under [TCP/IP Settings] is set to On for IPP printing.
If you want to set the key as use key, first disable the above settings and then set the key as use key.
