Configuring a Computer that Performs Printing
Configure all the computers to be used for printing so that they can be used on an SMB network.
Connecting to an SMB Network
1
Perform the following procedure.
From the [Start] menu, select [Control Panel], and then click [Network and Internet Connections] → [Network Connections].
From the [Start] menu, select [Control Panel], and then click [View network status and tasks] → [Manage network connections].
From the [Start] menu, select [Control Panel], and then click [View network status and tasks] → [Change adapter settings].
From the [Start] menu, select [Control Panel] → [Network Connections] → [Local Area Connection].
From the [Start] menu, select [Control Panel], double-click [Network and Sharing Center], and then click [Manage network connections].
2
Display the [Local Area Connection Properties] dialog box.
Click [Properties].
If the [User Account Control] dialog box appears
Click [Yes] or [Continue].
3
Make sure that the check boxes for the following options are selected.
[Client for Microsoft Networks]
[Internet Protocol Version 4 (TCP/IPv4)] (or [Internet Protocol (TCP/IP)])
If the check boxes are not selected, select them.
4
Double-click [Internet Protocol Version 4 (TCP/IPv4)] (or [Internet Protocol (TCP/IP)]).
5
Click [Advanced] in the [General] tab.
6
Enable NetBIOS over TCP/IP.
(1)
Display the [WINS] tab.
(2)
Select [Enable NetBIOS over TCP/IP].
(3)
Click [OK].
7
Continue to click [OK] until all the dialog boxes close.
If a message that prompts you to restart the computer appears
Restart the computer.
Installing the Printer Driver
A printer driver is required for printing. Following "Printer Driver Installation Guide", install the printer driver.
For details on the procedure for viewing "Printer Driver Installation Guide", see " Installation."
If the screen that prompts you to select a port appears during the installation
Click [Add Port].
Select [Network], and then click [OK].
From the list, select [Workgroup Name], [Server Name], and [Printer Name] specified in " Configuring the Protocol Settings" respectively.
