Pressing [
] ( Settings) displays the common Setup menu. indicates that the procedure is performed by pressing [ ] or [ ] on the control panel. indicates that the procedure is performed by pressing [OK] on the control panel. |
After performing the configuration
To enable the settings, perform a hard reset or restart the printer.
For details on a hard reset, see "Canceling All the Jobs (Hard Reset)."
To go back up the hierarchy
Press [
] ( Back). About the control panel
For details on the control panel, see "Control Panel."
Settings), select [Network] using [
] and [
], and then press [OK].
You can specify the settings when the printer is either online (the
Online indicator is on) or offline (the Online indicator is off). |
] and [
] and [
], and then press [OK].|
