WARNING
WARNING |
Do not dispose of used toner cartridges in open flames. This may cause the toner to ignite, resulting in burns or fire.
Do not store toner cartridges or paper in a location exposed to open flames. This may cause the toner or paper to ignite, resulting in burns or fire.
When disposing of a toner cartridge or waste toner container, place the toner cartridge or waste toner container into a bag to prevent the toner from scattering, and then dispose of the toner cartridge or waste toner container according to local regulations.
If you accidentally spill or scatter toner, carefully gather the toner particles together or wipe them up with a soft, damp cloth in a way that prevents inhalation.
Never use a vacuum cleaner that does not have safeguards against dust explosions to clean up spilled toner. Doing so may cause a malfunction in the vacuum cleaner, or result in a dust explosion due to static discharge. |
CAUTION |
Keep the toner cartridges and other consumables, such as a waste toner container, out of the reach of small children. If the toner or other parts are ingested, consult a physician immediately.
Do not attempt to disassemble the toner cartridge or waste toner container. The toner may scatter and get into your eyes or mouth. If toner gets into your eyes or mouth, wash them immediately with cold water and consult a physician.
If toner leaks from the toner cartridge or waste toner container, be careful not to inhale the toner or allow it to come into direct contact with your skin. If the toner comes into contact with your skin, wash with soap. If the skin becomes irritated or you inhale the toner, consult a physician immediately.
