Precautions when specifying [Mixed Sizes]
The printer performs printing without checking the paper settings in the printer driver.
Make sure that the paper specified in the printer driver matches that loaded in the paper drawer before using the printer. If you are using the UFR II printer driver, load custom size paper whose long edges are 8.50 in. (215.9 mm) or less in landscape orientation.
Feeder Selection).
] and [
], and press [OK].
] and [
], and then press [OK].
Paper size is registered.
] and [
], and press [OK].
Since the printer driver's [Paper Type] default value is [Printer Default], it is normally not necessary to change the printer driver settings.
Whenever you change the printer driver settings, match them with the paper settings on the control panel. |
] or [
], and then press [OK].|
The paper type is registered.
Next, specify the following settings.
