Cleaning the rubber pad in the paper drawer
08X4-0LC
Cleaning the rubber pad in the paper drawer may prevent the printer from frequently feeding multiple sheets of paper at a time.
If you have any questions on how to clean the rubber pad in the paper drawer, or if you feel uncomfortable cleaning the rubber pad in the paper drawer by yourself, contact your local authorized Canon dealer.
Do not use cleaning agents or detergents.
When wiping the rubber pad in the paper drawer, use a cloth dampened with water and well wrung out. Do not use cleaning agents or detergents, including ones containing grease or oil.
Do not touch the rubber pad in the paper drawer directly with your hand.
When cleaning the rubber pad in the paper drawer, make sure not to touch it directly with your hand.
1
Pull out the paper drawer.
If the paper feeder is installed, pull out the paper drawer of the paper feeder also.
2
Clean the rubber pad in the paper drawer.
Making sure not to touch the rubber pad in the paper drawer directly with your hand, wipe the rubber pad in the paper drawer with a cloth dampened with water and well wrung out.
3
Set the paper drawer in the printer.
If the paper feeder is installed, insert the paper drawer of the paper feeder also.
