"Profiles" Cannot Be Selected or Edited
08X4-0JU
When the [Allow Profile Selection] and [Allow Setting Edition] check boxes are cleared, selecting and editing a "Profile" are restricted.
To select or edit a "Profile", select the check box using the following procedure.
1
Open the printer folder.
2
Right-click the icon for this printer, and then select [Printer properties] or [Properties] from the pop-up menu.
3
Change the settings for [Define Document Property].
(1)
Display the [Profile] tab.
(2)
Select the [Allow Profile Selection] and [Allow Setting Edition] check boxes.
If you cannot change the setting
You need administrative rights to change the setting.
Contact your system administrator.
4
Click [OK].
