e-ManualTopSite mapHelp
Top » Security Settings » Setting Keys and Certificates
08X4-0E4
When using SSL encrypted communication, IEEE802.1X authentication or IPSec encrypted communication, authentication settings are necessary for the user to check the public key for encryption, the private key for decryption and key information.
See the following according to your system environment and the options that you want to specify.
When creating and using a key and its certificate with this printer
Newly create a key pair (the public key and private key) and its certificate.
Confirm the contents of the certificate of a created key.
Delete a created key and its certificate.
When using a key/certificate file created by a device other than this printer
Install a key/certificate file created by a device other than this printer on this printer.
Register a key pair (the public key and private key) and its certificate in a key/certificate file installed on this printer so that you can use them in the printer.
The number of key and certificate which you can create, register, or install
You can create and register up to eight "keys and certificates" (the total includes the one that is installed). Also, only one key and certificate file can be installed. If you cannot create, register or install them, delete unnecessary keys and certificates.
About a Key/Certificate File which can be installed on this printer
The key generation algorithm is "RSA". You can only install files with the extensions ".P12" or ".PFX".
The file format which you can register is a PKCS#12 file in DER (binary encoding) format.
