Type
Desktop Page Printer
Printing System
Semiconductor laser + xerographic system
Toner fixing system
On-demand fixing system
Resolution
600 dpi
Printing speed
(Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²) when printing Letter size paper continuously)
42 pages/min. (1-sided printing)
20.5 pages/min. / 10.25 sheets/min. (2-sided printing)
Warm up time
(Time from power on to printer ready) |
28 seconds or less
Recovery time
(Time from the sleep mode to printer ready) |
0 seconds when the printer is in Sleep Mode 1 (the Panel Sleep mode)
10 seconds or less when the printer is in Sleep Mode 2 (the Printer Sleep mode)
10 seconds or less when the printer is in Sleep Mode 3 (the Deep Sleep mode)*
First print time
(When performing 1-sided printing on Letter size paper and outputting face-down)
8.5 seconds
Paper size
Drawer 1/Drawer 2, 3 (Optional)
Standard sizes:
A4, B5, A5, A6, Legal, Letter, Executive, Statement, Foolscap, and 16K Custom paper sizes*:
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)
Multi-purpose tray
Standard sizes:
A4, B5, A5, A6, Legal, Letter, Executive, Statement, Foolscap, 16K, Index Card, Envelope DL, Envelope No.10, Envelope ISO-C5, and Envelope Monarch Custom paper sizes*:
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)
Paper capacity
Drawer 1/Drawer 2, 3 (Optional): Approx. 500 sheets
Multi-purpose tray: Approx. 100 sheets
2-sided printing
Standard sizes:
A4, Legal, Letter, Foolscap Custom paper sizes:
Width 8.27 to 8.50 in. (210.0 to 215.9 mm), Length 11.00 to 14.00 in. (279.4 to 355.6 mm) |
Paper output
Face-down/Face-up
Output capacity
Face-down output tray: Approx. 250 sheets
Face-up output slot: Approx. 50 sheets
Noise
(measured in accordance with ISO 7779, declared noise emission in accordance with ISO 9296)
LwAd (declared A-weighted sound power level (1 B = 10 dB))
During standby: Inaudible *
During operation: 7.3 B or less
LpAm (declared A-weighted sound pressure level (bystander position))
During operation: 54.5 dB
Operating environment
(Printer unit only)
Temperature range: 50 to 86°F (10 to 30°C)
Humidity range: 20 to 80% RH (no condensation)
Power supply
120 to 127 V, 60 Hz
Power consumption (68°F (20°C))
Maximum: 1,500 W or less
Average during operation: Approx. 700 W
Average during standby: Approx. 14 W
Average during Panel Sleep Mode (Sleep Mode 1): Approx. 14 W
Average during Printer Sleep Mode (Sleep Mode 2): Approx. 5.3 W
Average during Deep Sleep Mode (Sleep Mode 3): Approx. 0.9 W*
When the main power switch is turned OFF: 0.5 W or less
Consumables
Toner cartridge
Canon GPR-40 Black Toner
Canon GPR-40 H Black Toner
Weight
Printer unit and included parts
Printer unit (excluding the toner cartridges and drum cartridge): Approx. 36.6 lb (16.6 kg)
Toner cartridge: Approx. 3.1 lb (1.4 kg)
Consumables and optional accessories
Toner cartridge (Canon GPR-40 Black Toner): Approx. 3.1 lb (1.4 kg)
Toner cartridge (Canon GPR-40 H Black Toner): Approx. 3.7 lb (1.7 kg)
Paper Feeder Unit PF-45 (including the drawer): Approx. 12.1 lb (5.5 kg)
CPU
528 MHz + 264 MHz
Memory (RAM) capacity
768 MB
Host interface
USB interface:
Hi-Speed USB × 3 (1 top and 2 back)
Network interface:
Shared 10BASE-T/100BASE-TX/1000BASE-T (RJ-45)
Full duplex/Half duplex |
User interface
LCD:
132 x 65 dots
F-STN liquid crystal display LED indicator:
9
Operation key:
12
ROM slot
1
SD card slot
1
Built-in control command
PCL5e, PCL6, PostScript 3 emulation, UFR II, PDF, and XPS
Built-in fonts
PCL:
93 Scalable fonts, 10 Bitmap fonts
PS:
136 standard fonts
Printable area
PCL5e/PCL6:
Data cannot be printed within a 0.167 in. (4.2 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper. UFR II/PS:
Data cannot be printed within a 0.20 in. (5 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper.
Network interface
Supported protocol
TCP/IP (Frame type: Ethernet II)
AppleTalk
NetWare
SMB (option)
Print application
LPD
RAW
IPP/IPPS
FTP
WSD
