Viewing the e-Manual
Symbols Used in the e-Manual
The following are descriptions of warnings and cautions used in the e-Manual to explain handling restrictions, precautions, and instructions that should be observed for your safety.
WARNING
Indicates a warning concerning operations that may lead to death or injury to persons if not performed correctly. To use the machine safely, always pay attention to these warnings.
CAUTION
Indicates a caution concerning operations that may lead to injury to persons if not performed correctly. To use the machine safely, always pay attention to these cautions.
Indicates operational requirements and restrictions. Be sure to read these items carefully to operate the machine correctly, and avoid damage to the machine or property.
Indicates a clarification of an operation, or contains additional explanations for a procedure. Reading these notes is highly recommended.
Indicates an operation that must not be performed. Read these items carefully, and make sure not to perform the described operations.
Keys and Buttons Used in This Manual
The following are examples of how control panel keys and on-screen buttons are depicted in the e-Manual.
Type
Depiction in the e-Manual
Example
Control panel keys
[Key icon] + (Key name)
[ ] (Job Status/Cancel)
Buttons on computer operation screen and so on
[Button name and so on]
[OK]
Screenshots Used in the e-Manual
The contents of the screenshots used in the e-Manual are the default settings.
Depending on the system configuration, the contents of the screenshots may partly differ.
The functions of the printer driver may be changed due to upgrade.
Illustrations Used in the e-Manual
The illustrations of the toner cartridge used in the e-Manual are those for Canon GPR-40 H Black Toner.
Although the power cord used in this manual is as the one in the following illustration, the form of the power cord may differ depending on the country or region.
Abbreviations Used in the e-Manual
Abbreviations of Operating Systems and Printer Model
In the e-Manual, operating systems and printer model are abbreviated as follows.
Microsoft Windows XP operating system
Windows XP
Microsoft Windows Vista operating system
Windows Vista
Microsoft Windows 7 operating system
Windows 7
Microsoft Windows Server 2003 operating system
Windows Server 2003
Microsoft Windows Server 2008 operating system
Windows Server 2008
Microsoft Windows operating system
Windows
imageRUNNER LBP3580
LBP3580
» Before You Start » Using the e-Manual » Viewing the e-Manual
08X4-00F
