» Troubleshooting » Other Problems » When SSL Is Enabled, the Remote UI Does Not Start, or the IPP Printing Cannot Be Performed
Perform the following procedure.
<Cause> The file related to key management is broken.
Solution
Select [Network] → [Remote UI Settings] → [SSL] using the control panel, and then make sure that [SSL] is set to [Off].
Restart the printer.
Regenerate the key and certificate and specify the settings for SSL from the Remote UI.
4.
051R-0LA
