» Troubleshooting » Other Problems » SSL Cannot Be Enabled
Perform the following procedure.
<Cause> The key pair and its certificate to be used are not registered.
Solution
Register the key pair and server certificate that are used.
In order to use the SSL encryption communication function, it is necessary to create keys and certificates and to register the key pair and server certificate that are used.
051R-0L9
