» Troubleshooting » Other Problems » The SD Card Cannot Be Used
Perform one of the following solutions according to the cause.
<Cause 1> [SD Card] in the Control Menu options in the Setup menu is set to [Off].
Solution
Set [SD Card] to [On], and then perform a hard reset.
<Cause 2> An error has occurred in the SD card.
Solution
Perform formatting in [SD Card Maintenance] in the User Maintenance options in the Setup menu.
If the same error still occurs, replace the SD card.
<Cause 3> The SD card is not installed properly.
Solution
Turn the printer OFF, and then check if the SD card is installed properly.
<Cause 4> The data cannot be saved on the SD card because there is not sufficient free space in the SD card.
Solution
Delete any unnecessary jobs from among the jobs saved on the SD card.
051R-0L7
