Troubleshooting
Poor Printout Results
The Last Page Cannot Be Printed
Perform the following procedure.
<Cause> The command that notifies of the end of the data is not sent from the computer. (The
Job indicator is on.)
Solution
Press [
Online) to place the printer offline, and then select [Form Feed] in the Reset menu.
Outputting Data (Forced Output)
If you print using an application that does not have a printing function, [Form Feed] is performed because the last page in which data is less than one page remains in the memory.
051R-0L0
