» Troubleshooting » Poor Printout Results » Printed Data Lies outside Paper
Perform one of the following solutions according to the cause.
<Cause 1> When the following settings in the [Select Feeder] menu are set to [Mixed Sizes], custom size paper whose long edges are 8.50 in. (215.9 mm) or less is loaded in landscape orientation and printed (only when the UFR II printer driver is used).
Size of the paper in the multi-purpose tray
Drawer N (N = 1, 2) size
Solution
Load the paper in portrait orientation, and then print again.
<Cause 2> When the UFR II printer driver was not used, custom size paper was loaded in portrait orientation to be printed.
Solution
Load the paper in landscape orientation, and then print again.
<Cause 3> Paper is not loaded properly in the paper drawer or multi-purpose tray.
Solution
Load the paper properly.
<Cause 4> The printing position is adjusted in [Adj. Start Position].
Solution
051R-0KW
