» Troubleshooting » Poor Printout Results » The Overall Print Result Is Faint
Perform one of the following solutions according to the cause.
<Cause 1> The setting for the toner density is not appropriate.
Solution
Adjust the toner density for printing to a darker setting.
<Cause 2> [Toner Save] is enabled.
Solution
UFR II Printer Driver
Perform the following procedure in the printer driver.
Display the [Quality] sheet.
Click [Advanced Settings].
Set [Toner Save] to [Off].
PCL/PS Printer Driver
See Help of the PCL/PS printer driver.
You can specify the same setting from the printer's control panel.
051R-0KK
