» Troubleshooting » Paper Jams » Attention (Paper Jams)
Before removing the jammed paper, see "Important Safety Instructions."
CAUTION
Do not take your hands off the transport guide.
Do not take your hands off the transport guide until it moves back to its original position when tilting the transport guide toward you. The transport guide may snap back to its original position, and this may result in personal injury.
Leave the printer ON when removing the jammed paper.
If the power is turned OFF, the data being printed will be deleted.
Do not remove the jammed paper forcefully.
Removing jammed paper with excess force may cause the paper to tear or damage the inside of the printer. Remove the paper by pulling it gently.
If the paper is torn
Remove all remaining pieces of paper.
Do not touch the high-voltage contacts (A) or the electrical contacts (B).
This may result in damage to the printer.
Do not touch the transfer roller (C).
Print quality may deteriorate.
Do not touch the feed rollers (D).
This may result in damage to the printer or a printer error.
051R-0JR
