» Troubleshooting » The Printer Takes a Long Time to Start the Print Job
Perform one of the following solutions according to the cause.
<Cause 1> The printer is cooling down to maintain print quality. (Especially after narrow paper is printed)
Solution
Wait a moment. The printer automatically cools down the inside. After cooling is completed, the printer resumes printing.
<Cause 2> This problem may occur in some applications depending on the processing type of the print data. (Windows 2000/XP/Server 2003)
Solution
If you are using the PCL/UFR II printer driver, performing the following procedure may be able to solve the problem.
UFR II Printer Driver
Display the [Finishing] sheet.
Click [Advanced Settings].
Change the [EMF Spooling] setting.
PCL Printer Driver
See Help of the PCL printer driver.
051R-0J7
