» Troubleshooting » Printing Cannot Be Performed » Printing Cannot Be Performed (via the Print Server) » The Print Server for Connection Cannot Be Found
Perform one of the following solutions according to the cause.
<Cause 1> The LAN cable is not connected properly.
Solution
Connect the print server to the client computer with the LAN cable properly.
<Cause 2> The print server has not been started up.
Solution
Start up the print server.
<Cause 3> The printer is not specified as a shared printer.
Solution
Specify the printer as a shared printer.
For details, see the following item in "Printer Driver Installation Guide."
"Installation" - "Print Server Settings"
For details on the procedure for viewing "Printer Driver Installation Guide", see "Installation."
<Cause 4> The user does not have permission to access the print server or printer.
Solution
Ask your network administrator to change the user permissions.
<Cause 5> [Network discovery] is not enabled. (Windows Vista, 7, and Server 2008)
Solution
Perform either of the following procedures.
From the [Start] menu, select [Control Panel].
Click [View network status and tasks].
Set [Network discovery] to [On].
Click [Change advanced sharing settings].
4.
Specify [Turn on network discovery] in [Network discovery].
Double-click [Network and Sharing Center].
051R-0J5
