» Managing the Printer » Setting Items » [Reset] Menu
[Reset] Menu
Setting Item
Setting Value
Setting
[Soft Reset] ([Hard Reset])
Resets the printer when a problem is occurring or you want to cancel printing.
[Form Feed]
When a job is canceled from the computer or the data is less than one page, the data may remain in the printer memory, and the job may not be completed properly. As long as the printer remains in this state, you cannot print the next job because the printer cannot receive the next data. In this case, force the printer to output the print data using the procedure for this item.
[Shut Down]
Shuts down the functions of the printer.
If you are using WSD printing, the shutdown notifies the computer that the printer is turned OFF.
After executing a shut down, the printer cannot receive data, and panel operation becomes invalid.
Cycle the power of the printer if you want to print the data again.
051R-0AY
