Table description
Bold values in the table indicate the default settings.
Setting Item
Setting Value
Setting
[Fit to Page]
[Off], [On]
Set it to enlarge or reduce to fit the effective print area of the specified paper.
[Enlarged Print Area]
[Off], [On]
Set whether to expand the effective print area to the edges of the paper without leaving margins around the edges of the paper.
[N on 1]
[Off], [2 on 1], [4 on 1], [6 on 1], [8 on 1], [9 on 1], [16 on 1]
You can print multiple pages of the PDF file data arranged on one page. When multiple pages are printed, they are arranged from the top left.
[Comment Print]
[Off], [Auto]
Specify whether to print the comments inside the PDF file that are specified for printing.
[Halftones]
[Text]: [Resolution],
[Gradation], [High Resolution] [Graphics]: [Resolution], [Gradation], [High Resolution] [Image]: [Resolution], [Gradation], [High Resolution] |
You can select the halftone display method from
[Resolution], [Gradation] and [High Resolution]. [Resolution] allows you to perform printing that combines smooth gradation with edge quality. It is suitable for printing graphics or graphs that use gradation.
[Gradation] allows you to print with a sharp gradation and well-balanced texture, contrasting light and shade, which is best suited for printing photo images.
[High Resolution] allows you to print in fine detail so that the edges of text data can be seen clearly. It is suitable for printing data containing text and fine lines.
[Grayscale Conversion]
[sRGB], [NTSC], [Uniform RGB]
Select the method for converting color print data to
grayscale for printing. When it is set to [sRGB], it calculates the grayscale value using the sRGB standard color conversion method.
When it is set to [NTSC], it calculates the grayscale value using the NTSC standard color conversion method.
When it is set to [Uniform RGB], it takes the average value of the Red, Green and Blue color values as the grayscale value.
[Dot Gain Adjustment]
[-10%], [-5%], [Standard],
[+5%], [+10%] |
You can adjust dotted areas to change darkness and lightness of painted areas. A higher number specifies a darker printed area.
