» Managing the Printer » Software That Can Be Used for Managing the Printer » Remote UI » Starting the Remote UI » Attention (Remote UI)
When using SSL encrypted communication
To use SSL encrypted communication, a key and its certificate need to have been created and the key needs to have been registered as the default key.
For details on the SSL encrypted communication function and the procedure for registering a key, see "Setting Keys and Certificates."
If the Remote UI does not start when SSL is enabled
There is a possibility that the file related to key management is broken. Perform the following procedure.
Press [ ] (Settings) on the control panel, select [Network] → [Remote UI Settings] → [SSL], and then make sure that [SSL] is set to [Off].
Restart the printer.
Regenerate the key and certificate and specify the settings for SSL from the Remote UI.
4.
When using a proxy server
If you cannot connect the computer to the printer via a proxy server when using a proxy server, add the IP address of the printer to [Exceptions] (the addresses that do not use the proxy server) on the settings for the proxy server of the Web browser.
The setting varies depending on the network environment. Consult your network administrator.
About Cookies
Configure your Web browser to enable cookies.
Setting priority
For details on the setting priority for when specifying the same item using a method other than the Remote UI as that specified using the Remote UI, see "Setting Priority (When Specifying the Same Item Using Multiple Methods)."
If the Remote UI is running on multiple computers at a time, the latest settings are valid.
If you want to log in as Administrator, we recommend that only one Remote UI should be running at a time.
051R-09R
