» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (AppleTalk) » Macintosh Network Settings
Configure the Macintosh network settings.
1
Select [System Preferences] from the Apple menu.
2
Click [Network].
3
Check the settings for the network port.
(1)
Select [Network Port Configurations] from [Show].
(2)
Make sure that the [Built-in Ethernet] check box is selected.
(If the check box is not selected, select it.)
4
Make sure AppleTalk is active.
(1)
Select [Built-in Ethernet] from [Show].
(2)
Click [AppleTalk].
(3)
Make sure that the [Make AppleTalk Active] check box is selected.
If [Built-in Ethernet] does not appear in [Show]
Select [Network Port Configurations], and then select the [Built-in Ethernet] check box.
5
Close the [Network] dialog box, and then save the settings.
051R-09A
