» Printer Installation » Specifying the Printer's Initial Settings » Specifying a Type of Printer Driver
When printing from a computer by USB connection, specify which of the following printer drivers is used.
UFR II
UFR II XPS
PCL5e
PCL6
PS3
XPS (Direct)
You can select the type of printer driver to be installed at the time.
When installing the printer driver manually
Be sure to match the setting of this item and the type of the printer driver to be installed. You cannot use printer drivers of a different type.
1
Press [  ] (Settings).
2
Select [Control Menu] using [  ] and [  ], and then press [OK].
3
Select [Select PDL (PnP)] using [  ] and [  ], and then press [OK].
When the message is displayed, press [OK] to continue.
4
Select the printer driver to be used using [  ] and [  ], and then press [OK].
The setting value is changed.
Cycle the power of the printer or perform a hard reset to make the setting effective.
051R-02K
