Type
Desktop Page Printer
Printing System
Semiconductor laser + xerographic system
Toner fixing system
On-demand fixing system
Resolution
1200 dpi/600 dpi
Printing speed
(Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²) when printing Letter size paper continuously)
・35 pages/min. (1-sided printing)
・17 pages/min. / 8.5 sheets/min. (2-sided printing)
Warm up time
(Time from power on to printer ready) |
28 seconds or less
Recovery time
(Time from the sleep mode to printer ready) |
0 seconds when the printer is in Sleep Mode 1 (the Panel Off mode)
10 seconds or less when the printer is in Sleep Mode 2 (the Deep Sleep mode)*
First print time
(When performing 1-sided printing on Letter size paper and outputting face-down)
7 seconds
Paper size
Drawer 1/Drawer 2 (Optional)
Standard sizes:
A4, B5, A5, A6, Legal, Letter, Executive and 16K Custom paper sizes:
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)
Multi-purpose tray
Standard sizes:
A4, B5, A5, A6, Legal, Letter, Executive, Statement, 16K, Index Card, Envelope DL, Envelope No.10, Envelope ISO-C5, Envelope ISO-B5, and Envelope Monarch Custom paper sizes:
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)
Paper capacity
Drawer 1: Approx. 250 sheets
Drawer 2 (Optional): Approx. 500 sheets
Multi-purpose tray: Approx. 50 sheets
2-sided printing
A4, Legal, Letter
Paper output
Face-down/Face-up
Output capacity
Output tray: Approx. 150 sheets
Sub-output tray: 1 sheet
Noise
(measured in accordance with ISO 7779, declared noise emission in accordance with ISO 9296)
LwAd (declared A-weighted sound power level (1 B = 10 dB))
During standby: Inaudible *
During operation: 7.06 B or less
LpAm (declared A-weighted sound pressure level (bystander position))
During operation: 54.2 dB
Operating environment
(Printer unit only)
Temperature range: 50 to 86°F (10 to 30°C)
Humidity range: 20 to 80% RH (no condensation)
Power supply
120 to 127 V, 60 Hz
Power consumption (68°F (20°C))
Maximum: 1,060 W or less
Average during operation: Approx. 550 W
Average during standby: Approx. 14 W
Average during Panel Off Mode (Sleep Mode 1): Approx. 14 W
Average during Deep Sleep Mode (Sleep Mode 2): Approx. 1 W*
When the main power switch is turned OFF: 0.01 W or less
Consumables
Toner cartridge
Canon GPR-41 Black Toner
Weight
Printer unit and included parts
Printer unit (excluding the toner cartridges and drum cartridge): Approx. 25.6 lb (11.6 kg)
Toner cartridge: Approx. 1.8 lb (0.8 kg)
Consumables and optional accessories
Toner cartridge (Canon GPR-41 Black Toner): Approx. 2.2 lb (1.0 kg)
Paper Feeder Unit PF-44 (including the paper drawer): Approx. 9.0 lb (4.1 kg)
CPU
528 MHz + 264 MHz
Memory (RAM) capacity
768 MB
Host interface
USB interface:
Hi-Speed USB (1)
USB (1 front and 1 back)
Network interface:
Shared 10BASE-T/100BASE-TX/1000BASE-T (RJ-45)
Full duplex/Half duplex |
User interface
LCD:
132 x 65 dots
F-STN liquid crystal display LED indicator:
8
Operation key:
12
ROM slot
1
SD card slot
1
Built-in control command
PCL5e, PCL6, PostScript 3 emulation, and UFR II
Built-in fonts
PCL:
93 Scalable fonts, 10 Bitmap fonts
PS:
136 standard fonts
Printable area
PCL5e/PCL6:
Data cannot be printed within a 0.167 in. (4.2 mm) margin (0.39 in. (10 mm) margin for envelopes) on all sides of the paper. UFR II/PS:
Data cannot be printed within a 0.20 in. (5 mm) (0.39 in. (10 mm) for envelopes) margin on all sides of the paper.
Network interface
Supported protocol
TCP/IP (Frame type: Ethernet II)
AppleTalk
NetWare
SMB (option)
Print application
LPD
RAW
IPP/IPPS
FTP
WSD
