Setting Job Suspension for Detection of Multi-Sheet Feeding
Multi-sheet feeding refers to feeding of multiple sheets of paper at a time from the paper feeding section. This setting enables you to set the machine to suspend the job when multi-sheet feeding is detected.
Depending on the size of paper or operation mode of the machine, paper may remain inside the machine. In this case, the job may not be restarted automatically.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Feed Settings].
Press [Suspend Job When Multi. Sheet Feed Detected].
4.
Select [On] or [Off], → press [OK].
Details of each item are shown below:
[On]: The job is suspended when multi-sheet feeding is detected, and a message will be shown. Check the paper and output results, and then restart printing according to the message.
[Off]: When the optional POD Deck-D1 is installed, any unnecessary paper is output to the escape tray and the job is restarted automatically. If not installed, the job is suspended and a message will be shown. Remove jammed paper according to the message.
When set to "Off", because detected paper is output to the escape tray, the following pages may become out of order and incorrect output may be produced.
