Do not change settings for this function even when they are shown unless you are an Administrator. If you need to change the settings, consult a service representative. If the settings are changed, the [Fiery] functions of imagePRESS Server may become disabled.
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Settings]
[View Settings]
Show Images: On, Off
On
No
No
Show Animated GIF Images: On, Off
On
No
No
Enable Table: On, Off
On
No
No
Fit Web Page Into Screen Size: On, Off
Off
No
No
Use JavaScript: On, Off
On
No
No
Use Word Wrap: On, Off
Off
No
No
Use Japanese Hyphenation: On, Off
Off
No
No
Format: Std CSS only, Std CSS + Style Attribute, Std CSS + Style Attribute + External Imported CSS
No
No
Standard CSS: CSS1, CSS2, CSS3
CSS1
No
No
Show Flash Contents: On, Off
On
No
No
Flash Animation Frame Interval: Short, Medium, Long
Medium
No
No
[Home Page Settings]
URL
Use Current Page as Home
(NULL)
No
No
Home Page during Startup: On, Off
On
No
No
[Auto Clear Settings]
Display during Auto Clear: Show Home Page, Show Blank Page, Keep Last Page
Show Home Page
No
No
[Security]
Use SSL 2.0: On, Off
On
No
No
Use SSL 3.0: On, Off
On
No
No
Use TLS 1.0: On, Off
On
No
No
Certificates
Enable/Disable
Details
No
No
Display Mixed HTTPS/HTTP Pg: On, Off
On
No
No
Trusted Server Address
No
No
Restrict Share Device Information: On, Off
On
No
No
Display Server Certificate Auth. Warning: On, Off
Off
No
No
Displ Warning when Entering Secured Page: On, Off
Off
No
No
Displ. Warning when Leaving Secured Page: On, Off
Off
No
No
[Cache]
Use Cache: On, Off
Each Session, Each Access, Cache Priority
Off
No
No
Clear Cache: Yes, No
No
No
[Cookie]
Cookie Handling: Accept, Block, Prompt
Accept
No
No
Delete Cookies: Yes, No
No
No
[Privacy Policy and Regulations]
Restrict URL Entry : On, Off
Off
No
No
Restrict Add/Edit Favorites: On, Off
Off
No
No
Restrict Editing Home Pages: On, Off
Off
No
No
Restrict Add/Edit Page Memos: On, Off
Off
No
No
Restrict Printing: On, Off
Off
No
No
Restrict File Upload: On, Off
Off
No
No
Restrict History Display: On, Off
Off
No
No
Dept. ID/User Name with History: On, Off
Off
No
No
Full Screen: On, Off
Off
No
No
Hide Buttons in Toolbar: On, Off
Off
No
No
Hide Address in Toolbar: On, Off
Off
No
No
Hide Web Access Button: On, Off
Off
No
No
[Proxy Settings]
Use a proxy server (Display Only)
No
No
Proxy Server Address (Display Only)
No
No
Port Number (Display Only)
No
No
Use proxy auth. (Display Only)
No
No
Address Without Using Proxy
(NULL)
No
No
Use HTTP1.1 for proxy connection: On, Off
Off
No
No
[Version]
Version (Display Only)
No
No
