Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Output Report]
[TX/RX User Data List]
Yes, No
Yes
No
[Common Settings]
[Print on Both Sides]
On, Off
Off
Yes
Yes
[Select Drawer]
Switch A: On, Off
On
Yes
Yes
Switch B: On, Off
On
Yes
Yes
Switch C: On, Off
On
Yes
Yes
Switch D: On, Off
On
Yes
Yes
[Reduce Fax RX Size]
On, Off
On
Yes
Yes
Reduction Mode: Auto, Fixed
Auto
Yes
Yes
Reduction %: 75% to 97%
90%
Yes
Yes
Reduction Direction: Vertical & Horizontal, Vertical Only
Vertical Only
Yes
Yes
[2 on 1 Log]
On, Off
Off
Yes
Yes
[Print RX Page Footer]
Print, Do Not Print
Do Not Print
Yes
Yes
[YCbCr RX Gamma Value]
Gamma 1.0, Gamma 1.4, Gamma 1.8, Gamma 2.2
Gamma 1.8
Yes
Yes
[Interrupt and Print RX Jobs]
On, Off
Off
Yes
No
[Handle Files with Forwarding Errors]
Always Print, Store/Print, Off
Always Print
Yes
Yes
[Forwarding Settings]
Receive Method:, Validate/ Invalidate, Register (Registered Forwarding Settings), Delete, Details/ Edit, Print List, Forward w/o Conditions, E-Mail Priority
Yes
Yes*1
[Set Fax/I-Fax Inbox]
[Set/Register Confidential Fax Inboxes]
Inbox No.: 00 to 49
Yes
Yes
Register Box Name
(NULL)
Yes
Yes*2
PIN
(NULL)
Yes
Yes
URL Send Settings
(NULL)
Yes
Yes*2
Initialize
Yes
No
[Memory RX Inbox PIN]
Seven digits maximum
(NULL)
Yes
No
[Use I-Fax Memory Lock]
On, Off
Off
Yes
Yes
[Memory Lock Start Time]
Everyday (1 to 5),
Specify Days (Sun to Sat, 1 to 5),
Off
Off
Yes
Yes
[Memory Lock End Time]
Everyday (1 to 5),
Off
Off
Yes
Yes
[Divided Data RX Timeout]
0 to 99 hr.
24 hr.
Yes
Yes
[Always Send Notice for RX Errors]
On, Off
On
Yes
Yes
*1
Indicates items that are not delivered as device information.
Receive Method:, E-Mail Priority, Details/ Edit, Delete, Print List |
*2
Indicates items that are not delivered if a PIN is set.
