Available Paper Sizes
When received documents are printed, they are printed from the paper deck that has the same paper size as the received document.
If paper of the correct size is not available, the machine automatically selects a different paper size in the following order. (If all the switches in <Select Drawer> for [Select Drawer] (Settings/Registration) are set to 'On'.) The paper size is automatically selected in the same order, even if paper runs out during printing.
Available Paper Sizes for Received Documents
Size of Received Document
Paper Size Priority
11" x 17"
11" x 17" → LTR* → LTRR* → LGL* → STMTR x 2
LGL
LGL → LTR x 2 → LTRR x 2 → STMTR x 2 → 11" x 17"
LTR
LTR → LTRR → LGL → STMTR x 2 → 11" x 17"
STMT
STMTR → LTR → LTRR → LGL → 11" x 17"
* Paper size of received documents are automatically reduced before being printed on the paper size indicated.
Received documents can be printed on the following paper sizes and paper types:
Size: 11" x 17", LGL, LTR, LTRR, or STMTR
Paper Types: plain, recycled, color, coated, or custom paper type (paper with the following settings; Basis Weight: 17 lb bond to 28 lb bond (64 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
You can specify a paper deck to use for each function. (See "Enabling Paper Drawer Auto Selection.")
You can set the machine to reduce the size of received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can change the order of paper selection. (See "Paper Drawer Selection.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
» Scan and Send » Available Paper Sizes
0S9Y-0KX
