(Main Menu) → [Scan and Send] → [New Destination].
Protocol
System Requirements
Application
FTP
Solaris 10
MacOS X 10.8/10.9/10.10
RedhatLinux 9
Windows Server 2003 R2 SP2
Internet Information Services 6.0
Windows Vista SP2
Windows Server 2008
Windows Server 2008 R2
Internet Information Services 7.0
Windows 7
Internet Information Services 7.5
Windows 8
Windows Server 2012
Internet Information Services 8.0
Windows 8.1
Windows Server 2012 R2
Internet Information Services 8.5
Windows(SMB)
Windows Vista SP2
Windows Server 2008
Windows 7
Windows 8
Windows Server 2012
Windows 8.1
RedhatLinux 9
RedhatLinux 9
Mac OS X 10.5.8/10.6
Samba 2.2/3.0
WebDAV
Solaris 10
RedhatLinux 9
Apache 2.0
Windows Vista SP2
Windows Server 2008
Windows 7
Windows 8
Windows Server 2012
Windows 8.1
If you are using WebDAV and connect to the Internet using a proxy server, the proxy server must support IPv6.
Item
Description
Host Name
A host name is a name assigned to a host computer that provides services on the network. In this entry box, enter the name of the file server on the network as the destination of the send job.
If you select [FTP] or [WebDAV] as the server protocol, you can also specify a port number after the host name address by entering a colon (:) followed by the port number.
Example: 192.168.100.50:21000
When sending to an IPv6 host, specify the following settings for [Host Name]:
[IPv6 Address]:<Port Number>
Example: [5aed:90a0:bc05:01d2:568a:2fc0:0001:12ee]:21000
Make sure to enter the same port number for the Host Name as the one specified for the FTP server or WebDAV server to which you are sending your documents.
Folder Path
A folder path is a series of characters that signify the location of the folder. Specify a folder in the file server as the destination of the send job.
User Name
The login user name for the file server.
To enter the user name only:
Example: user_name
Maximum 20 characters
To enter the user name and the domain name:
Example: domain_name\user_name
Domain name: Maximum 15 characters
User name: Maximum 20 characters
To enter a UPN (User Principal Name):
Example: user_name@domain_name.com
Maximum 128 characters
Password
The login password for the file server.
If you select [WebDAV] as the server protocol in [Host Name], the HTTP protocol is used if you specify 'HTTP://' as the scheme at the start of the host name. The SSL + HTTP (HTTPS) protocol is used if you specify 'HTTPS://' as the scheme at the start of the host name. Specifying 'HTTPS://' as the scheme enables SSL communications between the server and the machine. You can confirm whether the SSL server certificate is valid when sending with WebDAV by setting [Confirm SSL Certificate for WebDAV TX] to 'On'.
You can only use UPN (User Principal Name) if you are sending to a computer belonging to a domain operated with Active Directory.
When sending to a file server on the Internet using WebDAV, proxy server settings may be required, depending on the environment of the destination. For details, see the manual provided with the imagePRESS Server.
