Printing Password Protected PDF Files
You can print password protected PDF files by entering the password required to open them.
This mode is only available for printing files stored in the memory media.
You can use this mode only when printing PDF files.
Press (Main Menu) → [Access Stored Files] → [Memory Media].
Select the desired Memory Media → select the directory where the file you want to print is stored.
Select the desired file → press [Print].
4.
Press [Options] → [Password to Open a Doc.].
To change the paper source, see "Paper Selection."
5.
Enter the password to open the document.
To open an encrypted PDF file, press [Encryption Password] → [Password] → enter the password.
When you open a PDF file with a policy, press [Policy Password] → enter the user name and password.
To print PDF files that forbid printing, or print PDF files that only allow low-resolution printing in high resolution, enter the master password.
6.
Press [OK] → [Close].
» Access Stored Files » Printing Password Protected PDF Files
0L3X-17S
