Printing Comments
You can add comments when printing PDF files.
This mode is only available for printing files stored in the memory media.
You can use this mode only when printing PDF files.
Press (Main Menu) → [Access Stored Files] → [Memory Media].
Select the desired Memory Media → select the directory where the file you want to print is stored.
Select the desired file → press [Print].
4.
Press [Options] → [Print Comments].
To change the paper source, see "Paper Selection."
5.
Press [Auto] → [OK] → [Close].
Comments specified within the PDF file are printed together with the file.
If you do not want to print the comments, press [Do Not Print].
» Access Stored Files » Printing Comments
0L3X-17R
