This mode can be used only for printing a file stored in a mail box.
(Main Menu) → [Access Stored Files] → [Mail Box].
[Upright Image]:
Prints the image upright on the paper.
[Sideways Image]:
Prints the image sideways on the paper.
Upright Image
Sideways Image
If you set any two of [Page Numbering], [Copy Set Numbering], or [Watermark] to print in the same position, a confirmation message appears when you press
(Start). |
(numeric keys).|
If no date is set, the date set in [Date/Time Settings] is printed. Confirm that the settings for [Date/Time Settings] are correct. (See "Current Date and Time.")
Printing performance may not be optimal, depending on the file content and combination of settings.
If you use [Print Date] with [Add Cover], [Insert Sheets], or [Job Separator], the watermark will not be printed on the inserted pages.
The Date Printing mode cannot be used with files including images with resolutions of less than 600 x 600 dpi.
You can also adjust the position of the date. (See "Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks.")
