If you want to create a group address, the destinations to register (such as e-mail addresses and file server addresses) must be stored beforehand.
(Main Menu) → [Scan and Send] → [Address Book].
The first character that you enter for the name is used for sorting the destination list when you press keys, such as [ABC], [DEF], and [GHI], on the Address Book screen. If [Search by Name] is pressed on the Address Book screen, a screen for narrowing the search in the Address Book appears.
To delete a destination, select the destination to delete → press [Delete].
If you want to store a group address, you can only select destinations registered in the same Address List.
If you want to register a file server in a group address, set [Confirm Before Sending] to 'Off'. You cannot send to a group address including a file server in which the Enter Password Each Time setting is set to 'On'. (See "Registering a File Server Address.")
