e-ManualTopSite mapHelp
Top » Remote UI » Managing Jobs
Managing Jobs
0L3X-204
The Remote UI provides you with job management capabilities, which enable you to check job status and pause/resume jobs.
The types of jobs that can be managed are:
Print jobs for the Copy and Print functions
Send jobs for fax transmission and e-mail transmission
Receive jobs for I-fax reception
Save jobs saved in the Memory RX Inbox or Confidential Fax Inboxes
If you set [Display Job Log] to 'Off', [Job Log] is not displayed.
Depending on the number of entries in the log, the log may take some time to be displayed.
You cannot use the Remote UI to check the job status or pause/resume encrypted secured print jobs.
The job management operations available using the Remote UI are the same as those that you can access from (Status Monitor/Cancel) on the control panel of the machine. For instructions on using the control panel, see "Basic Operations" and "Sending a Fax."
For more information on job management, see "Basic Operations."
For more information on send jobs, see "Scan and Send."
For more information on receive jobs, see "Fax/I-Fax Inbox."
For more information on send jobs for faxes, see "Sending a Fax."
