e-ManualTopSite mapHelp
Top » Scanner » WSD Scan » Scan Features of the WSD Scan
0L3X-1CR
This section describes how to use the scan features of the WSD Scan.
You can use the Network Scan function only in the following conditions:
Paper size:
LTR
Color mode:
Color
Resolutions:
300 dpi (fixed setting)
File format:
BMP, JPEG, PNG, TIFF
Press (Main Menu) → [Scanner] → [Online].
Set the scan function of the machine to online.
If [Scanner] is not displayed on the Main Menu screen, press [Show All].
After setting the machine to online, if the operation conflicts with other operations from scan driver, the earlier operation will be received.
Place your originals.
You cannot scan 2-sided originals even if you are using a feeder. Place 1-sided originals.
The available scanning size is up to LTR. For example, if you set 11" x 17" originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
For Windows 7, click (Start) on a computer → [All Programs] → [Windows Fax and Scan].
For Windows 8, place the cursor on the top right (bottom right) of the desktop → select [Search] → enter [Windows Fax and Scan].
If [Windows Fax and Scan] is not displayed in Windows 7, follow the procedures below.
Click (Start) → [Control Panel] → [Programs] → [Turn Windows features on or off] → [Print and Document Services].
Clear the check box for [Windows Fax and Scan] → click [OK].
Restart the computer.
4.
Follow the same steps and select [Windows Fax and Scan] → click [OK].
For information on functions of the Windows operating system, see the manual provided with the operating system, or contact Microsoft.
4.
Click [Scan].
5.
Click [New Scan].
6.
Click [Change] → select this machine as a scanner → click [OK].
7.
Specify each setting.
[Profile]:
If you scan text originals, select [Document], or select [Photo] for scanning photos.
[Source]:
If you are using a feeder, select [Feeder (Scan one side)], or select [Flatbed] if you are using the platen glass.
[Paper size]:
Select LTR.
[Color format]:
[Color] is set.
[File type]:
Select from BMP, JPEG, PNG, and TIFF.
[Resolution]:
"300" is set.
8.
Click [Scan].
Scanned originals are displayed on the list.
Scanned files are stored in [Scanned Documents] folder in [Documents].
If you click [Preview], the scanned file is displayed, but it is not stored in a computer.
