e-ManualTopSite mapHelp
Category Top
Optional Equipment and System Requirements
Printing from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE 802.1X Authentication Settings
Selecting the IEEE 802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Setting the Waiting Time for Connection at Startup
Setting Up a Computer for Printing
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
0L3X-1YW
If you want to use IPPS printing, it is necessary to obtain the public key of the machine and install it in Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012 by following the procedure below.
Start the Remote UI of the machine → click [Continue to this website (not recommended)].
Double-click [Internet | Protected Mode:On], located on the bottom-right of the Web browser.
Select [Trusted sites] → click [Sites].
https://<the IP address or host name of the machine> appears.
4.
Click [Add] → [Close].
5.
If [Enable Protected Mode (requires restarting Internet Explorer)] is selected, deselect it → click [OK].
The display returns to the Remote UI screen.
6.
Close the Web browser → start the Web browser → perform step 1 again.
7.
Click [Certificate Error] on the right of the address bar → select [View certificates].
8.
Confirm [Install Certificate] in the dialog box that appears.
9.
In the certificate import wizard, click [Next] → select [Place all certificates in the following store] → click [Browse].
10.
Select [Trusted Root Certification Authorities] → follow the instructions on the screen to close the wizard.
11.
If you deselected [Enable Protected Mode (requires restarting Internet Explorer)] in step 5, select it again.
